Fog light switch need help
not trying to make you sound like a rookie, but did you guys try turning it all the way to the right where the headlights come on then pull it out?
if that doesn't work, does it have the fog light symbol on the switch at all? if not maybe a previous owner switched out the switch and did not get a fog light compatible one.
grats to your buddy!
you may have bought a pickup that didn't originally have fogs and had em put in, but not fully wired, or the original switch took a crap and they went to a bone yard and got the switch out of a truck without fog lights.
Maybe the PO replaced the headlamp switch for some reason with a non fog switch ??
This is the only picture I could find quick with the fog lamp icon on it.
This is just a SWAG before you spend any cash at a dealer.
If it looks like the picture above with the light and 3 lines with the perpendicular line through them, and the arrow pointing down, it is a fog lamp switch.
If it will not pull out, sounds like the switch is messed up, as if the PO tried the fog lamp switch mod and really jacked up the switch.
Take a look at this thread on getting the switch out, and take a look at the ramp and pin on the switch post to see what is holding it up.
http://www.svtlightnings.com/svt/how...s/foglamps.htm
