Leaking axle
Old Jan 8, 2012 | 04:02 PM
fordf150farmer's Avatar
Leaking axle
I did a quick search but didn't find anything.
I got back to school the other day and I noticed that my front axle had puked some gear oil out of the breather tube. I really don't have any idea where to start with this one guys. Anyone had this happen? It is only coming out of the vent tube, which comes out on the passenger inner fender and leaks right on top of the shock/frame/axle shaft. I don't know what would cause this... Everything seems to be fine. The 4x4 works, I haven't noticed any vibrations out of the ordinary. Any help would be appreciated.
Old Jan 9, 2012 | 08:10 AM
Contender's Avatar
Was the oil milky? Have you been in deep water lately?
Old Jan 9, 2012 | 09:56 AM
grizzstang's Avatar
Was your truck recently on it's side or the roof.
Is your diff overfull? Is or was your vent tube plugged or partially plugged?
Old Jan 9, 2012 | 12:46 PM
thanks for the reply guys.
Ummmm.... as far as I can tell, the oil isnt milky, the ***** is everywhere and seems to be just plain ol' gear oil. I haven't been upside down, and I haven't touched the diff since I got the truck a couple of years ago, so it shouldn't be over full. the closest thing to deep water would have been a couple of big puddles over Christmas break, but nothing that would have submerged the front end.
Would getting to hot cause this? If so, then why is it getting to hot? Maybe time for a fluid change?
Like i said everything seems to be fine (as fine as a 15 year old truck with 191,000 miles can be expected to be any way). This problem is really the only indication that there is trouble in river city.
Old Jan 9, 2012 | 12:49 PM
as to a plugged vent tube... well i am not sure, but she sure as hell isn't plugged now haha.
Old Jan 12, 2012 | 01:12 PM
https://www.f150online.com/forums/ot...al-issues.html
After some googling, i found this thread, and was wondering if anyone ever found a solution, or if a bad casting was really the issue. (my build date is around june 96) Should i just look for a new front axle from bone yard out of a newer truck?
Old Jan 12, 2012 | 01:23 PM
jbrew's Avatar
Heat is usually all it is. To much of it. Either the diff fluid has broken down or it's the wrong type.
Contamination as well. Like if you rinse the engine compartment out or the breather has fallen off. It's also possible, that if you loose your lower wheel well skirt (they fall off) 0n the passenger side, you may catch road water drain. Over time, that can add up.
Old Jan 12, 2012 | 05:38 PM
How likely is it that broken down fluid would cause this? This to me from what i know about the truck is the most likely option. I have no idea when the last oil change was done on the front end, and the truck just clocked 191,000 miles.
Thanks for the response. If the weather permits i may do a fluid change this weekend.
Old Jan 12, 2012 | 06:01 PM
jbrew's Avatar
Very likely. You can feel some what fortunate that the breather wasn't plugged. When the breather plugs and the gear fluid heats up, you'll blow the seal instead.
Old Jan 12, 2012 | 07:22 PM
deerhunter7979's Avatar
jbrew, not trying to jack this thread but I have a parts question I think you can answer. Any way to ask you?
Glen
Old Jan 13, 2012 | 10:18 AM
jbrew's Avatar
Glen
Yes, thru PM's. Ask here, if you want.
Old Jan 13, 2012 | 10:45 AM
Someone on here once said you have a part number for generic Bosch oxygen sensors that are much less expensive then OEM ones, just that they do not come with the electrical plug on them. I would have to solder in my plug. Can you hook me up with the part number?
Old Jan 13, 2012 | 11:03 AM
jbrew's Avatar
I'll PM yuh.
