Geschwärzt's Transformation
Make sure you have that lower control arm as far down as it will go. You may need to rent a coil spring spacer. I dident need one when doing my 2 inch spacer but your spring and setup is prolly different. What i did was get the top of the spring in first then use my foot to press down the lower control arm as far as it will go and put in the spring.
thats the ball joint....... and there is a 1/4" inch gap between the end of the control arm and and the side of my tire.
im a med student and nothing puts me under stress, but this is working on my nerves...
nice. Always better to get wheels with less back spacing than wheel spacers. even tho im running 2'' wheel spacers and wheels with correct back spacing for my truck. ( i like my wheels sticking out the sides a good bit)
