plastic and fiberglass
Old Dec 30, 2011 | 12:59 PM
BOOMER2011's Avatar
does fiberglass and resin stick to plastic?
Old Dec 30, 2011 | 04:30 PM
pizzaman711's Avatar
With the right prep, it can be done. But you'd need to brace the back of the plastic with wood or something else like that because if the plastic flexes any it'll crack the fiberglass right off of it. What are you trying to fiberglass?
Old Dec 30, 2011 | 04:41 PM
joh408's Avatar
Quoted from FGF:
Originally Posted by Greg S
Plastics and fiberglass don't really bond at all. If possible it's best to stick with plastic when you are modifying something that is plastic to start with. If you are adding a large panel area that is fiberglass then you need to rough up the plastic and drill holes in it so that you can have the resin go through the plastic and make a mechanical bond with it by sandwiching the plastic between two layer of fiberglass.
Old Dec 30, 2011 | 09:09 PM
My01SCrew's Avatar
Originally Posted by pizzaman711
With the right prep, it can be done. But you'd need to brace the back of the plastic with wood or something else like that because if the plastic flexes any it'll crack the fiberglass right off of it....
This is what happened and caused me to scrap my console modification.
Old Dec 30, 2011 | 09:41 PM
lltoolj's Avatar
what are u doin now sir boomafoo? your always doin somthin different
Old Dec 30, 2011 | 11:12 PM
BOOMER2011's Avatar
i dont like my bed side covers
can i just fiber glass the hole the spray it with bed liner?
Old Dec 31, 2011 | 12:35 AM
Are you talking about the stake pocket holes?
Old Dec 31, 2011 | 09:19 AM
BOOMER2011's Avatar
no the plastic bed side cap, if you take that off there is about 15 holes on each side
Old Dec 31, 2011 | 10:02 AM
Oh okay I know what your talking about now, you should be able too but I'm not sure how it will hold up long term though, one even very slight flex even from just temperature change and it'll pop off.
Old Dec 31, 2011 | 10:28 AM
1clean42's Avatar
If its thick enough bed liner, like professionally done thick stuff, you can just duct tape over the holes and they'll spray over the duct tape. I've had two rhino/line-x sprayers tell me that so far.
Old Dec 31, 2011 | 12:08 PM
BOOMER2011's Avatar
I wondered about that too that's probley what I'm going to do
Old Dec 31, 2011 | 12:17 PM
1clean42's Avatar
Supposedly the liner will stiffen up and seal the duct tape. I'd use separate pieces of tape instead of one long strip. That just seems like it'd peel up easier than each little strip being sealed with the liner.
Old Jan 1, 2012 | 09:13 AM
BOOMER2011's Avatar
okay i got cha
think i can do it with hurculiner? or do i need to get it sprayed?
