i'm in a bind.. ( driveline)
Old Dec 20, 2011 | 03:34 PM
ford4life.'s Avatar
Are any of the bolts loose on the pan?
Nope stoped on its own.. than I cleaned up the area and I went around a checked them again. one or two where loose. I was going to drop than pan and use the stock gasket. but got under there and notice it didn't look like it was leaking.. Fluid was low. Added till full ran for 30 mins than drove it to advance. Still no signs of leaking
There might be a small leak around where the drive shaft enters the tailshaft though.. Cleaned that area and checking
Old Dec 20, 2011 | 07:14 PM
ford4life.'s Avatar
Guess the trans pan is still leaking. but only in one spot And it comes off of one of the bolt heads
Old Dec 20, 2011 | 10:07 PM
jethat's Avatar
To check the tail shaft all you gotta do is disconnect the rear ujoint and pull out the slip yoke. start the truck and put it in gear crawl under and look at the shaft if its bent youll know it instantly. It has a center notch from the lathe that made it. It should be right in the center. if it aint the shaft is junk. Been there done that..
Old Dec 20, 2011 | 10:43 PM
ford4life.'s Avatar
Nevermind.. I see now.
Old Dec 21, 2011 | 03:37 PM
ford4life.'s Avatar
well it looks fin. the whole case moves.. i took the rear driveshaft off put in 4x4 and was worse.. i'm thinking cv shafts now..
Old Dec 23, 2011 | 05:15 PM
ford4life.'s Avatar
Well all is good. Leak is fixed and vibration is gone.. Thinking when i put the rear driveshaft back on it put it on 180 so that stoped it.. I all so rotated the tires. But if it was tires im sure i would still feel it
Old Dec 23, 2011 | 08:07 PM
str8t six's Avatar
atleast you got it fixed.
Old Dec 24, 2011 | 12:53 AM
ford4life.'s Avatar
Yes. Thanks for the help guys.
