power window swap
do you think it is possable to swap power windows out of a 98 f150 xcab xlt to a 98 f150 reg cab XL? is the wire for the windows and locks ran by there own harness or does it tie in to the main ? does any one have a pic of where the door harness plugs in to the main harness or if it does or confirm it part of the main harnes and does not unplug
Just completed the conversion for my 2003 F150, using A1 Electric Power windows. There were no pre-installed wires. I bought wiring harness (2000 F150) with connectors from eBay and used that as a basis for wiring. Still had to add bunch of more wires. I also bought new door panels from eBay; wrapped real leather to armrest and the panel above it.
https://www.f150online.com/forums/me...fore-after.jpg Before: https://www.f150online.com/forums/me...44539-door.jpg After https://www.f150online.com/forums/me...p-complete.jpg (I've earlier converted all "dark gray" plastic parts to "light gray", so the new door panels complete the interior) |
2 Attachment(s)
i pulled the whole harness from the driver door to the plug on the driver kick panel then up behind the dash to the other kick panel then to the left door and i pluged the harnes in to my truck to see if my truck would power the locks but nothing work but i did not have it fully intalled i just had the door lock actuaters on the seats do they ned to be grounded to the door? The door switches on do i have to have it all plugged in. I have power to the main switch Attachment 25426
Attachment 25427 |
guys i need some help with this swap i dont think my truck has a G.E.M so the power mirrors and windows dont work but the door locks do when the harness is plugged in to my truck. is it possable to go around the G.E.M By just supplying switched 12v power to the window switch
Sent you PM with some info. I hope that will give you some ideas.
any one got a Power mirror wire schematic?
so i got all the parts in the doors and the panels on just have to run the wires in the door and along the fire wall and plug it all in then my xl will have power windows mirrors and locks
and thanks to the guys that send wire schematic
Im trying to do this swap too, l got everything already oem doors with power windows and need help wiring them up. Could yall pm me a wire schematic or some info?
Originally Posted by grinder42
(Post 4851523)
mom currently trying to do the same thing |
Originally Posted by David Carrillo
(Post 5269524)
hey were you able to get your power windows to work??
mom currently trying to do the same thing that was posted that back in 2012, hopefully he/she/it will respond 9 years later... |
Originally Posted by piggington
(Post 4844599)
(Post 5269545)
hey I was wondering how you made it all work I know it’s been long since this posts was up I’m trying to attempt this on my truck but can’t get it to work I have all oem parts just don’t know how to wire it
Paying attention isn’t your strong point is it??? |
(Post 5269524)
