severe vibrations at 60MPH
Old Dec 5, 2011 | 08:34 PM
richd860's Avatar
Not sure what it is,but when I'm on the highway,once I hit 60 mph,there is some severe vibrations.I can feel it in the steering wheel,and the manual shifter.Once I hit 70,it seems to subside a bit.It is also less noticeable,when I let off on the gas.Any ideas what it might be???
Old Dec 5, 2011 | 08:47 PM
pizzaman711's Avatar
Something out of alignment, if you feel it in the steering wheel it could be the front tires are out of balance.
Old Dec 5, 2011 | 09:04 PM
Herndon's Avatar
im with pizzaman. need to get your front end in the air and make sure everything is tight. if that all checks out then i would have the wheel balance checked
Old Dec 6, 2011 | 12:50 AM
spencerdrewh's Avatar
When was the last time you had your tires rotated and balanced?
Old Dec 6, 2011 | 05:06 AM
richd860's Avatar
Probably about 3 months ago.I know I'm due for new tires soon.Probably a great time to get them,now.
Old Dec 6, 2011 | 01:23 PM
If your tires are pretty worn out, there's a good chance they may be out of round or possibly have broken belts.
Old Dec 8, 2011 | 11:22 PM
There's a possibility they could be out of round like glc said. It could be as simple as them needing to be rotated and balanced though. I do mine every 5,000. My dad owns a shop and we do everyone elses every 5,000 as well.
Old Dec 9, 2011 | 01:58 PM
Ragu's Avatar
Went thru the same thing and turned out to be rear tire belt was separated. Got a pro rate (58 per cent) so replaced with four new ones.
Old Dec 26, 2011 | 07:15 AM
richd860's Avatar
Well,the vibrations are no longer a problem.I traded my '03 in for a 2008 F150 4X4.Sweet ride.Super cab,with a 5.4 triton V8,dual exhaust.Only has 35k on it.I'll get some pics on later,in the proper forum,of course.Merry Christmas!!!!!
