Misfire issues
Old Nov 28, 2011 | 11:14 AM
nick_james's Avatar
Misfire issues
Some background on the issue.
I have an 03 with the 5.4 and about a month ago I sprayed off the motor after riding the refuge after doin this it caused a miss on my number 3 cylinder. So I bought a new coil but by the time I was going to put it on the misfire stopped so I didn't change it. Which comes to now. After my truck sat for a couple days during thanksgiving break I had to come back to school, after driving about thirty minutes I made a stop and when I went to leave that misfire returned but went away after a couple miles. After some time the misfire came back but went away after a mile or two.
None of the wires feel or look loose. Is this a fouled spark plug or a retarded coil? I always thought when a coil went bad it was dead for good. Any help would be greatly appreciated.
Old Nov 28, 2011 | 07:27 PM
Toyz's Avatar
The cop's are sensitive to water, very. If you have to spray your engine off, you want to protect them. For now, they are probably fouled. I would pull them all off, remove the boots and let them dry out. Hopefully you can salvage them. If they have a lot of miles on them, consider them to be replaced.
Old Nov 29, 2011 | 01:19 AM
nick_james's Avatar
I ended up replacing the cop and blowing the well out on the number 4 cylinder. It would be the hardest one to replace. So we'll see if it solved the issue.
