Poltergeist SuperCrew Help New To Fords
Old Nov 15, 2011 | 07:22 PM
clonon's Avatar
I have a 2002 F150 Supercrew FX4 Lariat, The truck is all original but we had a heavy rain last night and this morning when I got in it my floormats were holding water. The fan started blowing full speed before I even got into the truck. It was hesitant to crank and when I got it off I heard multiple clicking noises from under the dash, and the heat remained on. My theft light was also blinking. I reached my hand under the dash and it was soaking wet, I have an appointment for someone come replace the windshield friday because it has two small rock pecks in it. Could there be anywhere else that it could be coming from? Any help would be greatly appreciated. Also, the truck has a sunroof. If someone else has already had this problem I apologize for reposting.
Old Nov 15, 2011 | 08:51 PM
enriched's Avatar
getting the windshield replaced might be good...also have the seal under the hood on the fire wall checked too. wouldn't rule out that sunroof either. a good automotive glass shop can make sure all is sealed up
But....suspect that the drain holes in the cowl (under the plastic grid area in front of the windshield ) and inner fender are plugged...especially if this sits outside much.
as to everything wet on the inside....the blinking anti-theft light...not a good sign....really be surprised if it will run....considering the the vast array of electrical under the dash...even if you get it sealed and dry may still present a host of electrical issues for some time to come. The carpet getting wet is the very least of the concern
Old Nov 15, 2011 | 09:14 PM
Red02FX4's Avatar
I haven't had this issue....yet. But from all I have read, the windshield will leak, sending water down to the GEM module behind the fuse box. Check there for wetness and clean/dielectric grease the connector plug
Old Nov 15, 2011 | 10:26 PM
Toyz's Avatar
x2
also check the sunroof drain lines, they clog up pretty easy
x2
With those electrical issues going on, I would suspect the GEM is taking on water.
Old Nov 19, 2011 | 04:51 PM
AlfredB18's Avatar
Yeah, leaky windshield. I had that happen where I was hearing this five beeps jazz from the fuse box area and I caught my OHC and fan still running when I came out for morning break at work..new windshield solved that problem.
