Aw man... orange fluid on my left front tire
Old Nov 15, 2011 | 06:53 PM
jmo1112's Avatar
So I just plasti dipped my wheels (that's another thread), and when I was putting the last tire back on, I noticed an orange fluid come out from behind the wheel and onto the tire as I was tightening the lugs. A quick google search led me to believe that a seal on the caliper is blown, but no one really said anything about an orange fluid. I backed in and out of my driveway, hitting the brakes pretty hard, and while they don't feel different, there is more fluid. Any ideas?
I was so excited about my new wheels, and now this.
Old Nov 15, 2011 | 06:58 PM
Toyz's Avatar
Did you run over an orange? Orange fluid eh.. . Brake fluid should be a clearish brown.
Old Nov 15, 2011 | 07:37 PM
jmo1112's Avatar
I know! It's weird. I hadn't even moved the truck since I had taken the tires off to paint the wheels. It had been on jackstands. But when I tightened the lugs, orange fluid. I'll try to get a picture, but it's dark and raining right now
Old Nov 15, 2011 | 08:15 PM
supercrewser13's Avatar
Just throwing this out there not 100 percent sure nore do i know how it would get there the only orange fluid i can think of is if you had the orange coolant in your truck
Old Nov 15, 2011 | 09:12 PM
enriched's Avatar
orange??
yeah check your fluids levels....
but gotta wonder if your neighbor is having some fun at your expense?? just a thought
was there ever resent work done on your truck? brakes or rear end work perhaps??
Old Nov 15, 2011 | 09:20 PM
jmo1112's Avatar
I recently replaced my master cylinder. Bled all the brake lines. Everything has been fine for a month. Brake fluid level is normal, and certainly not orange. I'm about to go back out there and take the tire back off and see what I can find.
Old Nov 15, 2011 | 10:17 PM
jmo1112's Avatar
I just took the tire off, had the wife step on the brake pedal, and I saw... nothing. At least I didn't see any leaks.
Here are some pics.
This doesn't seem like a lot of anything, but none of this was visible until I put the tire back on the truck.
Old Nov 15, 2011 | 10:19 PM
Toyz's Avatar
Looks like rust water from your tire. Maybe a leak around the bead? Or maybe you washed them, water got behind the bead and when you put them on, it dripped.
Old Nov 15, 2011 | 11:03 PM
Rusty water.
Dog ****?
Old Nov 15, 2011 | 11:20 PM
jmo1112's Avatar
Well, I'll take rusty water. I hope it's not dog ****. Haha. Hooray for overreactions!...
Old Nov 15, 2011 | 11:41 PM
Buxton91's Avatar
Yeah, looks like rust water to me.
Old Nov 16, 2011 | 10:34 AM
Pockets's Avatar
Or a paintball haha
Old Nov 16, 2011 | 02:00 PM
FordGuy24's Avatar
Yea that looks like rust...especially seeing there's water in the background in the picture. Probably just runoff
Old Nov 16, 2011 | 03:09 PM
BLUE20004X4's Avatar
It'd be worth looking at your caliper just in case while the tire is off, you'd see the running down of fluid though. It's oily obviously so it'll stick around. The orange in the pic says rust to me though. Looks like a bead issue, maybe a chip off the plasticoat while re-installing?
Old Nov 16, 2011 | 03:16 PM
Rusty water
