p0303 help please
Old Nov 9, 2011 | 05:27 PM
goatwrangler's Avatar
Angry p0303 help please
Hello all and sorry for the long post,
awhile back my truck started bucking and hesitating under load with no SEL.
I changed my spark plugs and the truck ran fine for awhile with no issues.
Just today driving to work this morning the ole truck started missing out on the highway and as soon as i got to work the SEL lite up. Read the code and pulled a p0303 out of it for cyl. 3 misfire.
The plugs have less than 2000 miles on them (autolite platinum)
When I got home I pulled the wires off the coil pack with the
truck running. The only one that didnt have the spark jumping from the
coil pack to the wire was cyl. #3 ? Can anyone help me out here ?
Do i need to try replacing all the spark plugs wires, swamping out suspected wire with a different cylinder or when its dark tonight let the truck run with the hood open to see if i can see a light show from the plug wires ?
Thanks for the help in advance !
Old Nov 9, 2011 | 05:35 PM
ern's Avatar
ern
misfire
Most likely the coil needs to be replaced. Swap it with another coil, and see what you get. Ern
Old Nov 9, 2011 | 05:45 PM
Most likely the coil....or possibly the spark plug...
Here are some possible casues.
Possible Causes:
Fuel injectors, related wiring, sensors and computer issues
Running out of gas, or poor fuel quality
Evaporative emissions system (EVAP) concerns: fuel vapors leaking into engine
Incorrect Fuel Pressure
EGR system concerns: leaking EGR valve or restricted ports
Base engine concerns: low compression, valve train problems and timing issues
Ignition system concerns including, but not limited to:
Faulty spark plugs
Faulty coil or related wiring
Ignition module or related wiring issues
Ignition related sensor faults or wiring issues
Faulty oxygen sensor(s)
Burned exhaust valve
Faulty catalytic converter
Poor compression
Defective computer
Old Nov 9, 2011 | 06:35 PM
Problem with swapping the coil is I don't have another to swap it out with...
Old Nov 9, 2011 | 06:37 PM
I have never changed my intake manifold gaskets and isolator bolts (got the famous codes last winter but not since probably feburary) maybe my egr ports are clogged ?
Old Nov 10, 2011 | 07:37 PM
quick update: I replaced my coil pack tonight after getting no spark from the number 3 tower. Found a crack in the ceramic on the bottom of the old coil pack directly underneath the number 3 tower.
