RC 5" Suspension lift work on 2003 5.4L Reg. Cab???
Old Oct 19, 2011 | 04:24 PM
KScountyboy's Avatar
Question RC 5" Suspension lift work on 2003 5.4L Reg. Cab???
I am hoping to do a lift on my truck this coming spring. In anticipation, I am starting to do research on different lifts and doing some shopping around.
I was looking on ebay at a Rough Country 5" lift for 97-03 4x4 and one of them said that the lift would not work on a Regular cab with the 5.4L. Is this correct? After seeing this, I went to RC's website and they say nothing about not working on a truck like mine.
Has anybody out there with a regular cab 5.4L installed this lift? Or another one that they would recommend?
Thanks for the help!
Old Oct 19, 2011 | 08:24 PM
hockeyfanjeff's Avatar
I have the RCD 5" which is a little more expensive than the Rough Country, but you get Bilstein 5100 Shocks and the rear lift is from an add-a-leaf instead of stacking blocks. Their website shows the lift installed on a truck identical to yours http://www.racecardynamics.com/produ...4wd150full.htm. The only difference is dependent on which transmission you have, the 4R70W or E4OD, not engine. I purchased mine from ntwonline.com
Old Oct 20, 2011 | 11:25 AM
thanks, that does look like a better way to go
