F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   1997 - 2003 F-150 (https://www.f150online.com/forums/1997-2003-f-150-118/)
-   -   Question for you guy's?? (https://www.f150online.com/forums/1997-2003-f-150/458911-question-you-guys.html)
sniknah Oct 18, 2011 02:16 PM
I have a 2001 f150 85k miles, I'm thinking of servicing the transmission. I had the dealer do it at around 40-50k (full flush) Now I 'm thinking of servicing the tranny again. Should I have it flushed again? Or is that just asking for problems? The tranny has never had any issues and I wan't to keep it that way. Or should I just drop the pan and replace the filter and add fluid? Any help would be much appreciated. Thank-you. RH
Bluejay Oct 18, 2011 02:18 PM
I would drop the pan, change the filter and add the required 6 or 7 qts of fluid. That is, unless the fluid looks dirty or burned, then I would drain ir all.
Alex_4.2L Oct 18, 2011 05:21 PM
what bluejay said
and Im sure you're safe going either way. Just don't overtorque the pan bolts when putting the pan back on. Ask me how I know. :o
88racing Oct 18, 2011 06:03 PM
X3!...... http://i877.photobucket.com/albums/a...0870ba-1-1.gif
sniknah Oct 18, 2011 09:58 PM
What type of filter would you guys reccomend? How much are they approx?
Patman Oct 18, 2011 10:41 PM
If the filter has been changed once you probably dont need to change it again, its usually only recommended on the first time into the trans to recover break in debris.
glc Oct 19, 2011 11:24 AM
The 2001 may have a torque converter drain plug too - if it does, drain it.
