Heat not working
Most likely the blend door, mines broke too but I've figured out if I just leave it set to heat and let it constantly blow for a while it'll slowly switch over over the course of about a month or so ha.
Touch the heater core hoses to make sure both are warm......if ones warm and the other one isnt then the heater is plugged and needs to be flushed or replaced......caution may be hot....
1. Check the engine coolant level when hot and cold.
2. Check for hot water to the heater core inlet hose.
3. Is the heater core outlet hose cool or cold?
If so, -
TEST the heater core for a plugged or partially plugged condition.
Try this first, let us know what you find.
