SHudder when towing - trans or ?
Old Oct 17, 2011 | 10:19 PM
tw_ford's Avatar
02 FX4 Supercrew with 4R70W.
165k miles
~12k since trans flush, 8 plugs changed and 2 Coil assembly replaced.
Truck shudders when pulling ~2200lb horse trailer. Did it once before and the dealer performed the above services about 12k miles ago.
Seemed to help.. until now. Towed 1k jet ski ~12 times for both short and long distances. Towed the trailer (2200lb empty and ~3100lb with pony) 3-4 times since then. Didnt notice anything then.
Is there a way to determine whether its a trans vs engine (coil?) issue? Since service did both - I cant determine from that experience.
Circumstances prevented checking fluid but will.... fluid last checked <2k miles ago.
Just thought of related question - did the tow pkg come with tranny cooler?
Thanks..
Old Oct 18, 2011 | 08:13 PM
serranot's Avatar
Well, these transmissions are known for a shudder when the fluid gets old, but that shouldn't be the issue here. Does it feel like you're driving over rumblestrips?
Old Oct 18, 2011 | 08:58 PM
tw_ford's Avatar
No -not really. I dont feel much through the steering.. but sometimes it almost feels like wheel hop.
It occurs pretty much at any speed - I went as high as ~60. Accelerating, decelerating, steady-state, OD on/off.... heck - i even put in N and coasted and felt it a bit.
I just dont want to throw $$ at possibilities till it gets fixed...
Thanks...
Old Oct 19, 2011 | 02:04 AM
Bluegrass's Avatar
Look at the possability of drive shaft U joints or a dry trans output shaft to yoke spline.
Good luck.
Old Oct 19, 2011 | 07:11 AM
enriched's Avatar
Possibly...your emergency brakes need attention?
but agreed with bluegrass with drive line inspection
or another COP going south, low grade miss-fire.
any codes present?
Old Oct 19, 2011 | 08:22 PM
tw_ford's Avatar
Dumb question - if it's throwing codes, would that be indicated by a "check engine" light?
Old Oct 19, 2011 | 09:38 PM
Bluegrass's Avatar
Sometimes. I depends on if the PCM detects an issue with the control solenoids and circuits.
If it's a mechanical issue the OD lamp may flash or light when a function has a problem, then the CEL may not light.
Old Oct 25, 2011 | 02:29 PM
ford_man_22's Avatar
My truck is having similar problems. I have an 02 Screw 5.4 4x4 that the tranny shudders like Im going over rumble strips when in or out of overdrive around 50-60. Doesn't matter if Im pulling anything now or not. I'm due for a transmission fluid change, but I'm afraid I have other damage. If anyone ever figures this out, PM me or email me.
Old Oct 25, 2011 | 03:32 PM
Galaxy's Avatar
I've had my tranny (actually the torque converter, or so I've heard) shudder, but has only done it a couple of times under severe sircumstances; very heavy trailer, taking off from a stand still on a grade. It was unmistakable in my scenario where it was coming from or what it was.
Old Oct 25, 2011 | 06:55 PM
2002 wonderboy's Avatar
Could it be the horse trailer? I had a cargo trailer(2000 lbs) that made a god awful shudder throughout. Thought it was the transmission getting ready to go. I did some investigating on the trailer and found one of the bolts fell out of the leaf springs, causing a severe wheel hop.
If you can associate the noise\shudder with the trailer I would look there first. make sure all the tires are properly inflated and check to see if there is any mud caked into one of the trailer wheels.
Also, I would Check the fluid level and also smell/color of the fluid to see if it is burnt
