97 F150 Lift and Tires Questions!
Hi guys I new here and have some questions about my truck. I want to run a 35 with a 3in bodylift. Can it be done. Im all for trimming some plastic if need be. I found some General Grabber 35x12.5x16 for $890 a set with free shipping. I dont have a lot to spend. Thanks for helping!
If you 4x4 yes, you might have to trim a little and possibly crank up your torsions some. If your 2x4 there's no chance of it fitting without serious rubbing.
What wheels are you going to run? The backspace on those depends on your rubbing.
Also are you going to install the body lift yourself, because the labor on them is far from cheap.
I'm running 35s with 3.55 and it is a little sluggish like westtnfx4 said but it's not horrible, I've had it like this for I guess over a year now and it hasn't bothered me enough to get it regeared, but then again I'd rather make my rent payments instead of putting more into the truck ha.
