Need Help, Suggestions Something.....
Old Aug 3, 2011 | 06:59 PM
txmoon's Avatar
So my problem is my 2002 5.4 Supercrew getting 9mpgs with combined highway/slight around town driving on a good day. I've searched forums, checked my truck and i am just stumped. August of 2010 my truck was turn apart motor wise and replaced cleaned from the block up. New head gaskets, heads got resufaced and cleaned, New injectors, new timing chains and tentioners, throttle body cleaned. New spark plugs. At the time the truck was running 34" BFGs and stock 373s. Then i would get around 10-11mpgs i think and this was the milage i was getting before the motor work. Before i drove my truck back to Tx I added 4:89s to the rear and 38"s. I think my average Highway milage from NC was 12-13mps. And i was completly horrified. I was expecting at the least 15 highway. I drive the truck as light as i can because i know the milage sucks and still cant raise it. The engine responds well, I step on the throttle and it picks up and gos. I have a friend with a stock 02 and I compared highway rpms.
His were
50mph - 1400rpm
55mph - 1500rpm
60mph - 1600rpms
Mine are
50mph - 1550rpm
55mph - 1700rpm
60mph - 1850rpm
65mph - 2000rpms
So they arent too off I dont think. As far as performance engine is stock with the air filter hood cut one of those free mods, dual exhaust from the manifolds back. So I welcome any and all reasonable suggestions. Especially guys running 38s and 488s. Thanks
Old Aug 3, 2011 | 10:15 PM
Bluegrass's Avatar
Only thing you can do at this point is look at the running live data for fuel tables out of limits and ignition timing out of normal range, as a possible place to start..
9 to 10 is pretty poor. I got that much pulling a race trailer round trips 300 miles at gross combined weight in the 12,000 lb range with a stock 4.6L.
If you have headers, are the OX senors in place? If not, your running on very rich fixed fuel tables and that will do it for sure along with the gear changes.
Good luck.
