start up
Old Jul 24, 2011 | 10:04 PM
03Screwon22's's Avatar
start up
hey guys, I have a 2003 f-150 supercrew, has only 70K im having problem starting it when its hott. it takes a while to crank it. I had it tuned up, new battery, no problem with the starter, new alternator. what could it be? fuel pump is running well.
Old Jul 25, 2011 | 07:17 AM
enriched's Avatar
Just to be sure have your fuel pressure checked ( actual PSI #'s)...the fuel Pump probably is fine...its a rule it out thing.
Has the fuel filter been changed with your "tune up"?
What was all done with this "tune up"?
What about the MAF sensor?...it might need a cleaning as well.
The throttle body might be in need of a good cleaning too...there are some EGR port in there that like to get carboned up
Old Jul 25, 2011 | 07:33 AM
My01SCrew's Avatar
You can do this yourself. I got a gauge at Autozone for about 35-40 dollars, which was cheaper than renting their gauge kit for the day and I get to keep it. Pressure should be around 35-40 PSI when the key is turned to run and if I remember right about 32 PSI once its starting.
