HELP! flashing check engine light
I can tell you for sure that a flashing check engine light is not a fuel pump issue.
It is associated with a cylinder that is not firing and passing unburnt gas that is burning in the cats for that side hence the warning CEL flashing to that effect.
This is why we told you of a missfire.
The discription of dragging the truck through the gears was not helpfull.
Good luck.
Good luck.
Good luck.
Good luck.
(and sorry for the lengthy description, just trying to be thorough, hoping someone may have had the EXACT problem.)
Here is an example of someone coming on asking for help, does not give all the details of the changes made so accurate help might be given, then gets ticked off when challenged.
Good that he bowed out because this was not going anywhere with the attitude developing.
