2wd 3.5 spindle lift Pics please!!!
Old Jun 27, 2011 | 03:26 PM
big_gun's Avatar
Question 2wd 3.5 spindle lift Pics please!!!
hey yall
ive been searching around the site and have yet to find a thread on 2wd
spindle lifts
i figure everyone can post up there pics here since we need one!
plus it will help me decide if i want my truck like this
better if they were 3.5in spindle lifts, but any would do as long as 2wd
Old Jun 27, 2011 | 03:34 PM
Lightning Expo's Avatar
Check out buxton91 he use to have that setup and so did I but don't have any old pics since I had it with a body lift. You can run 33s with that setup though. Just get the right backspacing on the wheels.
Old Jun 27, 2011 | 04:09 PM
97isnotold's Avatar
this is my old truck with a 3.5" spindle lift and a 1.5" level spacer with a 3" block on 265's if you want a little more lift. just an idea
Old Jun 27, 2011 | 06:20 PM
Jeff R.'s Avatar
heres mine, 3.5" fabtech spindles with a 3" block
Old Jun 27, 2011 | 08:53 PM
doby84's Avatar
heres mine
3.5 doetsch spindle, 1.5 daystar spacer
not a very good pic but might help
Old Jun 27, 2011 | 11:11 PM
Buxton91's Avatar
Here is a pic of mine when I had 3.5" spindles and a 1.5" daystar level. The rear was lifted with 3" blocks. I was running 33's and they rubbed the inner fender with my 10" wide wheels, but with an 8" wide or a +offset you shouldn't have any problems.
Old Jun 28, 2011 | 12:11 AM
Taylor has spindles, not sure how high, i want to say 2 or 3" lift
Old Jul 1, 2011 | 03:04 AM
Wild Bill's Avatar
3.5" spindles, 3" rear blocks, 265/75R16
Old Jul 1, 2011 | 04:05 AM
MmmBuckles's Avatar
he also has 2" springs
Old Jun 18, 2012 | 05:23 PM
Smitha6's Avatar
Will a spindle lift LEVEL the truck out or is the spindle lift too much and will make the back lower than the front?
Old Jun 18, 2012 | 06:01 PM
cstritz's Avatar
A 3.5" spindle will make the front sit higher than the rear. That's why most people put a block in the rear to level it out.
Old Jun 18, 2012 | 08:33 PM
pizzaman711's Avatar
It takes about 2" to level so you'll be sitting 1,5" high or so in the front.
