egr line
Old Jun 19, 2011 | 01:11 PM
Chuck172's Avatar
egr line
I am totally confused. I'm replacing the blown egr line from the valve to the exhaust manifold.
I managed to break loose the nut at the egr valve easily. Now for the confusing part.
I removed the old line. The bottom flare on the old tube is missing the collar. There must be some sort of adapter from the exhaust maniford that would end with a male thread that the flare nut on the new tube assembly would tie into.
Has anyone run into this before?
Old Jun 19, 2011 | 01:35 PM
Chuck172's Avatar
To clarify the above post.
Can anyone tell me what are the fittings that connect the exhaust maniford to the egr line?
Old Jun 19, 2011 | 01:52 PM
Chuck172's Avatar
Now I've found out it is called an egr adapter. It looks impossible to remove and replace. I understand its a dealer part also.
Anyone have any luck with this?
Old Jun 20, 2011 | 12:35 AM
jbrew's Avatar
Well, I'll give you some info, even tho I shouldn't and most won't even reply when you don't tell us "model year" and "engine size".
They're all different at that connection and both V8's have completely different set ups/adapters.
A 5four uses a 5four adapter and a 4six uses a smaller like nipple adapter. The 5four is more custom than the 4six, meaning , -you CAN repair the 4six with pipe thread parts from the hardware. The 5four, that's a dealership or salvage yard part.
Old Jun 20, 2011 | 11:28 AM
Chuck172's Avatar
I'm sorry I forgot to give the details of my truck.
2000 f-150 4.6
I guess I was in the panic mode when I got a look at the exhaust manifold job. It's really rusted and corroded. I managed to fix it. I machined a sleeved fitting with my lathe and press fitted it in place. It does the job.
