Tire question
Tire question
what size tires can i run with out rubbing ive got a 1998 f150
with a 3.5" spindles and 1.5" daystar for total 5" lift front and 3" rear i want to run 305/70/16 terra grapplers
If thats a 33/12.50 or 33/11.50 you'll be fine. Just check their specs sheet on the website to see what they actually measure out too. You could probably even do a 35/11.50 with minor rubbing over bumps and at full lock.
http://www.therangerstation.com/tech...nch_Tires.html
i think ill go with 305/75/16
it says 34"x12" is that right and if so will they rub
