Show off your 97-03`s with backracks!
Old Jun 8, 2011 | 10:55 PM
stugraham's Avatar
i am putting one on mine but i need to do a little fab work since its off an f250 and need to know where everything lines up on the truck you guys help would be greatly appreicated!!
Old Jun 9, 2011 | 11:10 PM
nhford's Avatar
recently added a back rack
Picked up a used rack last fall.
Had it powdercoated semi-gloss black.
Picked up the mounting kit ($100 fyi).
Got some vinyl letters printed out (something different).
I'm likin' it so far.
FYI, MFR will send you free BACK RACK stickers, just contact them.
Old Jun 13, 2011 | 09:04 AM
stugraham's Avatar
MFR? whats that and... looks great can i get a pic of the mounts? that would be great also! thanks! i have a toolbox and the rails are stupid u lose another 2 inches of your back window with having to lift it, so im fabbing my own out of flat steel angle and having it about a quarter of an inch off the box instead of 2 inches!
Old Jun 13, 2011 | 09:56 AM
nhford's Avatar
...MFR? whats that and... looks great can i get a pic of the mounts?...
MFR... (Manufacturer)
I can take some pics of my mounts.
FYI, there's a funky shaped/bent mounting bolt in the kit, one for each side.
Bolt has 3 bends to it @ different angles.
It bolts the bracket on top, and then to the inside wall of the bed.
A couple large washers keep everything snug to inside wall.
This bolt would not be easy to fab.
Fabbing the welded mounting brackets, doable.
Old Jun 13, 2011 | 10:07 AM
stugraham's Avatar
yea i figured... i am going to cut my bolt and fab it to work with my f150 ... it doesnt work cause the stake holes are soooo close to the cab of the truck... i couldnt see any logical way other than fabbing a bolt to make the brackets work... which apparently is what they have done
Old Jun 17, 2011 | 08:38 AM
nhford's Avatar
The bolts are bent, definitely held with a fixture / jig when formed.
Threads on each of my bolts were flattened at each end.
I had to have each bolt chased. I was not impressed.
I contaced the manufacture and let him know.
I asked if they were made in asia/imported, he said from the Amish.
Are there any Amish over in China?
Must be same Amish making that 'electric flaming space heater' seen on TV.
I've had my rack on for two months now.
Not impressed with the bracket quality considering I paid $100.
They didn't clean up any weld splatter before they painted the brackets.
Now that weld splatter is already coming through.
Paint has started to separate from the splatter, tiny rust spots are showing.
Old Jun 17, 2011 | 09:28 AM
stugraham's Avatar
yea thats BS, what should i do? tell them i bought it a couple months ago to put on my truck and havent till now and they gave me the wrong bolts see if i can get them to send me some new ones?
