Truck running bad found solution!
Old May 23, 2011 | 02:23 PM
stoker100's Avatar
Hi,
I guess IO ned to have 10 posts before I can place my truck for sale.
I did post a while back for a bit, not sure where they went.
I had an issue where the truck was running real bad!
Did the drain the CPU deal.
Actually pulled the tank and checked that both fuel pumps worked.
Cleaned MAF, etc.
Nothing helped!
What it ended up being is a spider had worked it's way passed my K&N filter someohow and had laid an egg sack on my MAF wire in the corner!. Could see it, and the contact cleaner wouldn't remove it. They are really sticky!
Findly removed the MAF completely since I was going to change it out. Upon some serious visual inspection found the egg sack.
Cleaned it up, installed it, reset the computer, drov around a bit at normal speeds and everything is now great!
I am building a house and running into trouble so I need to seel my 2002 HD with 52,500. 14,500 to a lucky person that has some cash or an ability to finance.
Live in Seattle WA.
Will chat for a while to get my 10 posts in.
I have an IPOD adapter that works great!
larry
