97 f150 steering column. HELP!
Old May 20, 2011 | 06:27 PM
97f150project's Avatar
I have a manual transmission on a 1997 f150 xlt and the steering column is going bad. Is there a crossover with the same model but with an automatic transmission? will this work? I am having a hard time fining a used steering column from a manual. Any help is greatly apprecated.
Old May 20, 2011 | 06:53 PM
IIRC the columns are the same with the auto shifter bolted on top of the column shaft housing, you'll need to swap your key cylinder, key removal button, and plastic trim
