No fuel pressure after installing engine
Old May 5, 2011 | 08:06 AM
fastford4x4's Avatar
I had fuel presure before I removed the engine and now I have reinstalled the engine I have no presure,i've only have
Power to 1 wire in the relay and can use a jumper wire to make the pump run...so what is wrong that both wires are not hot,is it my oil sending unit or some other sencer thanks in advanced
Old May 5, 2011 | 03:20 PM
Bluegrass's Avatar
In the circuit is a relay, and a crash sensor behind the right side kick panel at the top.
Try resetting the crash sensor first.
Good luck.
Old May 5, 2011 | 05:46 PM
Toyz's Avatar
What year and engine? What year engine was installed? Like Bluegrass said, check the inertia switch behind the passenger kick panel. The fuel pump wiring should not have been affected during the swap. But with the battery being disconnected and reconnected, the inertia switch may have tripped.
