Wheel stud replacement
Old Apr 26, 2011 | 10:21 AM
Bansheeman6100's Avatar
So after riding some
Very rough old roads on a recent roadtrip, some of my lugs nuts on my rear axle Cale loose am one of the studs sheared right off. So it's time replace it. Do I need to remove the halfshaft? There's not much stud left at all. And I really don't want to remove the shaft and replace the fluid, seeing as I just changed it last month. The truck is a 2000 model manufactured late 1999 with rear discs
Old Apr 26, 2011 | 11:48 AM
Glen R's Avatar
Not sure about the rear, but I replaced the fronts on my 98 with no issues. The front actually had a notched area to allow knocking the studs out and installing the new ones. Take a look and see if the rear has a notch to clear the base.
Old Apr 26, 2011 | 12:00 PM
fordf150farmer's Avatar
^^^^ this is what i would expect... i havent done it on one of these trucks but i did a windstar mini van, and it was as simple as drive out the old, shove the new one in as best i could with a pry bar, and then use a spacer and lug nut to pull it all of the way down.
Old Apr 26, 2011 | 01:33 PM
That's what I'm hoping to
Encounter. And correct me If I'm wrong but I believe they are 12mm studs
Old Apr 26, 2011 | 02:07 PM
joh408's Avatar
I think pre 99 had 12mm studs and after that it was 14mm. Not positive tho
Edit: Changed it back around. rednutbow was correct
Old Apr 26, 2011 | 02:58 PM
rednutbow's Avatar
^^ I think its the other way around, I have 14mm on my truck.
Old Apr 26, 2011 | 03:25 PM
joh408's Avatar
Ya I thought that at first but second guessed myself for some reason. Thanks for the correction
Old Apr 26, 2011 | 06:36 PM
Glen R's Avatar
Early are definitely 12, later 14. Found out for sure when I tried to use teh extra set of McGuards from my 98 on my Expedition.
Old Jul 12, 2011 | 10:37 AM
Well after a lot of procrastination in doing this, I'm selling the truck on Thursday and was gonna get this done tomorrow. I just climbed under the truck to take a look and it looks like I'm going to have to either remove the axle or to whole brake assembly? I have rear discs. Any input is appreciated!
