Tire size
Old Apr 18, 2011 | 07:42 PM
cstritz's Avatar
Tire size
Just ordered my daystar 1.5" leveling kit for my 2001 2wd scab. Will I be able to run 33's with the leveling kit on? if so what would the best tire size be? I would really like for it not to rub.
Old Apr 18, 2011 | 08:07 PM
pizzaman711's Avatar
Depends on the backspacing on your wheels are you still running the stock wheels?
Old Apr 18, 2011 | 08:30 PM
cstritz's Avatar
yes. as of now. would it be possible with the stock wheels?
Old Apr 18, 2011 | 08:34 PM
You can keep the stock wheels with the 1.5" spacer however I'm not sure what size tire you'll be able to run. Ask Buxton91 or wandell on here I'm pretty sure one of them would be able to tell you what tire size would fit best.
Old Apr 18, 2011 | 10:21 PM
wandell's Avatar
Yes, you can fit 33's using the OEM wheels or an 8 inch wide wheel with 4.5 inches of BS.
Old Apr 18, 2011 | 10:31 PM
Buxton91's Avatar
I ran 285/75/16's on 16x10 wheels with 4.5" backspacing and had no rubbing at all.
Old Apr 18, 2011 | 10:32 PM
Ha I figured you two would know the answer to this.
Old Apr 19, 2011 | 01:30 AM
cstritz's Avatar
so in order to get the 4.5" of bs on the stock wheels what size tire is that?
Old Apr 19, 2011 | 01:35 AM
4.5" of backspacing is the wheel not the tire. The stock 2wd wheels are like 6" or something like that. The less backspacing the more the wheel and tire will stick out from the body.
Old Apr 19, 2011 | 01:41 AM
Buxton91's Avatar
Well if you plan on using the stock wheels then you more than likely won't have any rubbing either. I know I didn't when I had mine.
Old Apr 19, 2011 | 02:01 AM
Possibly on the frame though when turning depending on how wide of a tire he chooses.
Old Apr 19, 2011 | 02:27 AM
joh408's Avatar
Stock rims have 4.5" of backspacing
Old Apr 19, 2011 | 02:19 PM
Buxton91's Avatar
With 285's on stock wheels I had no rubbing, But with 305's I rubbed on the sway bar. It was so slight that I would of never noticed if it wasn't for the 1" section on the sway bar that the paint had rubbed off of.
Old Apr 20, 2011 | 01:01 AM
cstritz's Avatar
So you ran 285/75/16 on the stock wheels with only a leveling kit and had no rubbing?
Old Apr 20, 2011 | 09:05 PM
Buxton91's Avatar
Correct, even without the leveling kit I had no rubbing but the tires were stuffed and had no room for flex when offroad.
