Which Lift should i go with for 2wd??
i have a 98 2wd extended cab f150
my original lift plan was to get the 1.5 inch level, 3.5 inch spindle, 3 inch body lift, and 3 inch rear blocks
but now im kind of wanting to just go with the fabtech 7.5 inch suspension
i want at least 7 inches of lift.
any suggestions??
any suggestions??
Yea you'd be at a horrible angle with a 3.5" coil and no new upper control arms, and you'd probably never ever be able to get it aligned anywhere close to where it needs to be. Just go fabtech 7.5 and then 3" bodylift. If that still isn't enough for you then put a 1.5" coil spacer in there too. That should have you clearing 37's and tucking 38's depending on brand of wheel, tire, backspacing, etc..
^^Agreed! That is the set I have and I'm running 37's with room for a 38
