Leaky back window
Old Apr 24, 2011 | 07:35 PM
PirateSignal's Avatar
The window tint took about 1-1/2 hours. Aside from standard install, it required several iterations of trimming once applied. Rear windows are tedious, but probably the most important window for a reg cab.[IMG][/IMG]
Old Apr 24, 2011 | 10:34 PM
kansasflareside's Avatar
What about leaks around the slider? Mine has a small gap on each side between the slider glass and the rest of the window glass.
Old Feb 5, 2016 | 11:44 AM
William Ellison's Avatar
Originally Posted by Spencer2009
I just fixed mine 3 weeks ago. I used something called Butyl tape. I picked it up at Napa Auto Parts for like $25. I used this how-to to do it my self. I tried using that Window weld caulk type stuff but it didnt work cause i didnt use but half a tube and made a big mess. They say if you use that stuff to use a tube and a half, didnt know that till after the fact so i found that Butyl tape and it fixed it right up. Car wash and 3 heavy heavy rain tested approved!
Hi there, What size butyl tape did you use? I see a lot of people saying 1/4 in. but there are several different sizes on amazon.
Thanks for your time
William Ellison
Old Sep 23, 2016 | 12:15 AM
samurai84's Avatar
The official TSB says to only use 8mm (5/16) foam core butyl tape. It specifically says not to use the solid butyl most people use. The official part number for the foam core butyl is E69Z19562A
