offroad y pipe for 4.6
Old Mar 26, 2011 | 07:47 PM
machsp33d's Avatar
Hey guys I got a bad cat on the left side, it gets red hot between the two. I tried takin the y pipe off but looks like it has to be cut...thinkin of cuttin between the cats and gutting them and running mil elims or is there an aftermarket y pipe that fits? I see the pacesetter has one for there long tubes and bassani does for lightnings... The shi++y thing is I just had the pass side manifold, gaskets and studs replaced a few months ago, coulda went with a long tube set! FML!
Old Mar 26, 2011 | 08:05 PM
anything that fits an L should fit, unless you're 4x4
you can gut the precats with no CEL repercussions, and you can gut the rears if you do sims or Gotts 02 sensor mod
Old Mar 26, 2011 | 08:39 PM
machsp33d's Avatar
I knew i forgot to say 4x4 and its an '02...
Old Mar 27, 2011 | 04:12 PM
oh and depending on cab configuration, i think there's one crossmember you can drop out of the way to remove the factory Y pipe out of it
Old Mar 28, 2011 | 10:53 AM
machsp33d's Avatar
lol so i forgot to mention its a screw as well. i was thinkin about one of them crossmembers but it was getting late so i put it back together...atleast everything will come apart easy next time i guess
