What is my rear end ratio
Old Mar 18, 2011 | 05:57 PM
jcon115's Avatar
Can someone help me out , I was told to look on my door Jamb for the axle ratio.....the only thing i can see relating to the axle is the number 18........can anyone decipher this or tell me exactly where i should be looking....1997 short box regcab stepside....... thank you very much ....
Old Mar 18, 2011 | 06:45 PM
joh408's Avatar
3.08 open
Old Mar 18, 2011 | 06:58 PM
ford4life.'s Avatar
Im wrong.. not the first time.
Old Mar 18, 2011 | 07:07 PM
joh408's Avatar
Thought 19 was 3.55 and 18 was 3.08
Old Mar 18, 2011 | 07:30 PM
ford4life.'s Avatar
my bad it is..
Old Mar 18, 2011 | 07:36 PM
joh408's Avatar
Don't worry I've been wrong plenty of times on here
Old Mar 20, 2011 | 12:30 PM
jcon115's Avatar
hmmmm ok so it is a 3.08 then ...... thanks very much guys willhelp alot i have been trying to figure out my towing capacity on this truck , have a boat that i figure is somewhere between 3500 and 3700 on the trailer , tandem axle with surge brakes ....... again very much appreciated all the help i have got on this site
Old Mar 20, 2011 | 06:00 PM
Which engine and transmission?
Old Mar 22, 2011 | 02:11 PM
jcon115's Avatar
Thumbs up
the truck has a 4.2 with a four speed auto tranny i looked in my book at the truck they say is good for 9000 lbs. with the class three hitch i have on there now ..... so i am okay for sure .... i appreciate all the response on here , this is a great site .
Old Mar 22, 2011 | 04:38 PM
No, that's the max tow for a 97 with all the right equipment (5.4 with 3.73's). A 4.2 auto with 3.08's is limited to 2000#. You have a very bad combination. With 3.31's it was 4800# and with 3.55's it was 5800#.
Old Mar 22, 2011 | 05:04 PM
rednutbow's Avatar
2000# in a 1/2 ton! holy jesus... I think a camry can pull that!
Old Mar 22, 2011 | 06:49 PM
That's the official limit - mine is only around 3000# in spite of the 3.55's - because I have a M5OD.
The 3.08's are very weak. If you want to pull that boat I'd go to the boneyard and get a complete rear axle assembly that has 3.55's.
Old Mar 22, 2011 | 07:48 PM
PirateSignal's Avatar
Yes, 9000Lbs is severly off. Heed the advise of the other posters.
I pull my offshore boat from MN to TX to MS for poker runs each season, and I can tell you if an accident happens and you are towing above your tow vehicle's weight limit, you are in serious trouble.
1. Your insurance company has no legal obligation to cover nor indemnify you.
2. You are sued by the other party and bankrupt... if someone is seriously injured you are bankrupt... and in jail.
This stuff has gotten more serious in the last several years. Know your tow vehicle's tow-weight rating.
Old Mar 28, 2011 | 08:15 PM
jcon115's Avatar
ok i went out and checked my owner's manual . GCVW IS 9000 lbs. the tow capacity is 4800 lbs. 4.2 with 3.08 rear end ratio and a four speed auto is good for 4800 lbs tow cap. ..... thanks for all your input everybody ...... truck only has to pull the boat one way ini the spring and one way in the fall 120 miles each direction I think I am fine ...... again thank you all for your information ....
Old Mar 28, 2011 | 10:27 PM
rednutbow's Avatar
I was looking on fordf150.net specs and they dont even list a 4.2L auto with 3.08's? It starts at 3.31's. It was for a 2002 truck, cause they dont have numbers for 1997. so did they stop putting 3.08's in auto trucks? or do you have 3.31's?
With 3.31's it rates the towing cap at 4800#
