How to door lock actuator 97-03
Old Mar 16, 2011 | 10:09 PM
ford4life.'s Avatar
1. These pictures are not mine. They help very well.
http://www.ford-trucks.com/user_gall...&albumid=12198
Couple things i want to point out.
Some of the connector colors are not the same.
Be sure to take mental note of how the key tumbler rod goes on. it will fall off.
the window rail has a clip on the back that will allow you to pull it farther away. Just make sure to put the clip back on the back side of where the rail sits. This messed me up for a wile.
Make sure no wire are bindind or snuged behind something. I had my pass side wires stuck behind the window rail. shorted out fuse blown.
Door locks fuse is #8 in the under hood fuse panel.
It really is a simple task once you do it once. took me awile to do my pass side. about 15 mins for drivers..
