I broke something changing my plugs
Old Mar 15, 2011 | 04:33 PM
jmo1112's Avatar
So as I was getting one of my spark plugs out, it took quite a bit of effort to turn the ratchet, but when it finally broke loose, it knocked my hand and the ratchet into some other wires, and I'm pretty sure broke this connector off. I don't know what this is, or what it goes to (at least I know it goes to the bottom of whatever that is in the picture). Just how screwed am I?
Old Mar 15, 2011 | 04:57 PM
sniknah's Avatar
I'm not sure what it is, but doesn't this **** you off! Seems to always happen to me. Or I drop a tool or piece in the engine.
Old Mar 15, 2011 | 05:09 PM
jbrew's Avatar
Evaporative Emissions Canister Purge Valve. You broke the white line stem on the solenoid.
Old Mar 15, 2011 | 05:43 PM
jmo1112's Avatar
Okay, so, I don't know what that means. How difficult/expensive is that to fix? And can I drive my truck with that stem broken? I haven't even tried to turn it on yet... I'm a little scared to
Old Mar 15, 2011 | 09:05 PM
sniknah's Avatar
Try a dab of super glue and you should be golden ?
Old Mar 15, 2011 | 09:18 PM
jmo1112's Avatar
Seriously? Or were you saying that with as just brainstorming (and if so, I appreciate you trying to help)? I looked up the part, but do I need to replace the solenoid, or the cable? Or do I need to replace it all?
Old Mar 15, 2011 | 11:34 PM
sniknah's Avatar
Not being a smartarse...but is it just rubber or a wire inside it?
Old Mar 15, 2011 | 11:36 PM
sniknah's Avatar
If you're going replace it...I would go to the bone yard. .02
Old Mar 16, 2011 | 01:12 AM
jbrew's Avatar
That's an Emissions vac supply line (white) connect. It's a white supply line that connects to the solenoid , you just can't see it from the pic. It's covered up. You can't glue that, you need a new one. I've broke those before, the solenoid stem is what's broke
Take an 8mm socket/ratchet set up and some dikes with you to the bone yard and get another. Or order a new purge valve assembly from the dealership.
You can run without it, just plug the line.
Old Mar 16, 2011 | 01:17 AM
Lightning Expo's Avatar
Seriously?
Old Mar 16, 2011 | 01:28 AM
jbrew's Avatar
Btw - Learn how to remove those Green and White elbows,- without breaking them lol. It can be done w/WD40 and patience. If you break the top ring, they won't stay connected. Hopefully you'll be able to practice with one from the salvage yard.
Old Mar 16, 2011 | 02:55 AM
jmo1112's Avatar
Gotcha. So is it the line that I need to replace, or the solenoid? Or both? Does that line just plug back into a new solenoid?
Old Mar 16, 2011 | 03:12 AM
jbrew's Avatar
The busted piece is stuck inside the little black rubber elbow. The line is fine, just pull the broken piece and plug it with a golf T or whatever until your able to get another assembly, - purge valve assembly that's bolted to the firewall with two 8mm bolts.
Old Mar 16, 2011 | 03:24 AM
jbrew's Avatar
You can see how it connects here, -and where it broke off the bottom of the solenoid -
Old Mar 16, 2011 | 09:40 AM
jbrew's Avatar
Diagram~ This is what broke (circled in red), plastic stem that the white lines rubber elbow connects to -
