HELP URGENT removing 4.2l 98 f150 engine
Old Mar 13, 2011 | 01:39 AM
stugraham's Avatar
Exclamation HELP URGENT removing 4.2l 98 f150 engine
need to know how to get the starter off the engine and the tranny the bolt is stripped is there anything else we can do ??
Old Mar 13, 2011 | 07:21 AM
jbrew's Avatar
Remove the other two bolts, - then grab a pry bar, cram it in between and apply outward pressure while rewinding. That should work with that one.
If not, -torch it.
Old Mar 18, 2011 | 12:13 PM
stugraham's Avatar
thanks i ended up using a stripped nut remover and breaking the stud off and breaking the starter housing luckily the starter was screwed anyways.. now just to get the stud out of my tranny
