Needs help/opinions with mods.
alllright!
i shall look for a can tomorrow!
Thanks for the info and help joh
Ill be sure to get up some pics of before the wash and after the wash, and before the bed liner and after the bed liner. ASAP.
You'll love that raptor liner, It's great stuff. The only problems that i could say I've had with it is a sharp metal corner from the latch on my cooler cut into it on my tailgate but other than that i throw stuff on it and slide things across all the time with no problems at all. Just watch out for those sharp edges! haha
heres a few pics i snapped yesterday of the truck before i washed it.
And some of the clearance i have bewtween my fender wheel body and valance.
Turnt straight
Turnt left on the drivers side, at the closest point of rubbing the body.
Turnt right on the drivers side, at the closest point of rubbing the valance.
So even with 4" BS i could run a 10" wheel even with it being that close?
But if i get a 10" wheel with 4" BS would the wheel stick out past the truck any more than the 7" wheels? or just be wider under the truck?
Two of the whole truck.
Turnt straight
Update: I have gotten my bumpers taken off. and sanded down, along with my rockers sanded down too. everythings tapped off. I shall be painting tomorrow. And putting the bumpers back on the next day. I will get pics up ASAP.
Also I tinted my ford ovals. I have pics of them also.
It's basically just an emblem delete. You cut out a section around the emblem on your grille, then using a second grille cut out the same size section from the honeycomb area and you use some type of a bonding adhesive to bond it to yours. Then all you do is paint it then reinstall. I think there is a write up somewhere on here.
