Help is this the wheel hub?
Old Jan 15, 2011 | 12:12 AM
supercrewser13's Avatar
Help is this the wheel hub? video
Just Recently Purchased another f150 and i beleive what i see is going to mean i have to replace the hub today i lifted the truck up and am able to rock the wheel and also the hub moves. i am linking a video just to get some second opinions or am i looking at a diffrent problem. also i hear the clanking from it some times and the abs i felt kick on once when it was not needed also when i lift the wheel off the ground and spin i hear it grinding. Can anyone confirm for me that this is probably what i am going to have to do?
http://s155.photobucket.com/albums/s...-01-19_631.mp4
video below just click
Old Jan 15, 2011 | 01:14 AM
Toyz's Avatar
Yessir, hub/wheel bearing. That's pretty bad. Check everything else while your in there. Upper and lower ball joints, tie rod ends, bushings etc.. But thats a hub for sure.
Old Jan 15, 2011 | 04:08 AM
Stephen87's Avatar
yep as toyz said its the hub alright, the same thing happened to me and it freaked me out a bit but after more than 200k miles I guess it was time to replace anyways. but yea get it replaced before your tire falls off
Old Jan 15, 2011 | 08:08 AM
thanks guys for the quick response ;ools like im picking one up today even if it the duralast one.
Old Jan 15, 2011 | 03:33 PM
letzgo4wheelin's Avatar
Since you have it that far apart, replace the ABS sensor, you should get a new one with the hub.
