stiff pedal
Old Jan 2, 2011 | 11:05 AM
1998f150wes's Avatar
stiff pedal
i was wondering if there is a way to fix the stiff pedal in my 98' f150 4.6 ext cab
Old Jan 2, 2011 | 11:42 AM
jutwan88's Avatar
accelerator?
Old Jan 2, 2011 | 12:37 PM
Toyz's Avatar
Cable may be getting old and deteriorating. Check that all the way to the throttle body. Also might be a good time to clean your throttle body along with the butterfly valve etc.
Heres what mine looked like years ago when I did it.. (My throttle was sticky, it would hang up then smooth out)
BEFORE
AFTER
Check the cable first. It's never a bad idea to clean up your TB either way. My truck ran so much better afterward. EGR ports were partially clogged.
Old Jan 2, 2011 | 05:53 PM
97f1504x4jim's Avatar
I had this problem on my 97 and i used a special tool for cleaning cables on dirtbikes and it made an improvement, not like brand new but made the pedal way easier to push then what it was.
