Transmission maintenance
Old Dec 27, 2010 | 10:44 PM
f150_truck's Avatar
I own a 2001 4.2L V6 truck and have 63K miles on it, never change the transmission filter or oil. I am thinking of doing an oil change with a transmission flush.
How can you tell if its a 4R100 OR 4R70W?
What is the diff in MERCON V and just MERCON oil?
Old Dec 28, 2010 | 02:33 AM
The 4.2 only came with a 4R70W. Use only Mercon V - you can't buy straight Mercon any more.
Old Dec 29, 2010 | 04:09 PM
f150_truck's Avatar
What's the difference other than cost between the aftermarket filter and a dealer. I know i can get a transmission aftermaket filter for maybe $15.
Old Dec 30, 2010 | 10:25 AM
What brand?
Old Dec 30, 2010 | 09:50 PM
f150_truck's Avatar
There's is a very popular brand here "Duralast"
Old Dec 31, 2010 | 08:26 AM
I would not use a Duralast tranny filter - that's Autozone's house brand. Go over to NAPA and get a Wix.
Old Dec 31, 2010 | 05:26 PM
f150_truck's Avatar
Thanks, for the info.
I found a supplier that sells this WIX filter for $22.
Old Jan 3, 2011 | 09:43 PM
f150_truck's Avatar
i did the change the filter and new gasket but notice there was a small leak coming from the tranny dipstick. I checked and is not overfill so my question is how do i replaced the dipstick?
Can i just replace the o-ring?
Old Jan 4, 2011 | 06:44 AM
enriched's Avatar
Should be a O-ring...bigger trick is unbolting the dip stick tube ...thinking that is attached to the exhaust manifold. Your lower miles are in your favor.
Also watch/inspect the tube carefully after you get it out...some have been known to rust out nearest to the exaust...not saying that is the case, just watch for it.
Old Jan 4, 2011 | 08:39 AM
biggrey's Avatar
The tube may leak a bit if you get the level too high when filling the trans. The level goes back down when you run the pump and fill the converter. My truck leaked when i changed the fluid but I cleaned it up and it hasn't leaked since.
Old Jan 4, 2011 | 07:08 PM
f150_truck's Avatar
Thank, I drove for a few miles and looked at the tranny dipstick and is not leaking anymore.
Old Jan 4, 2011 | 08:33 PM
Roadie's Avatar
The original gasket does not need replacement. If you used the gasket in the filter kit you probably made a mistake. The 2001 may have the torque converter drain plug. If so, you can drain all the fluid yourself without having to go to a shop.
Old Jan 5, 2011 | 09:45 AM
fordordie1's Avatar
i hear that a flush can start the trans (since it wasnt flushed regularly) to slip. i had my fluid just changed and pan cleaned(new filter of course) and it runs great
Old Jan 5, 2011 | 04:26 PM
There is a difference between a flush and a fluid exchange with a machine. I would never allow flush chemicals to touch a transmission.
