wheel bearings for 2002 fx-4 front end
I also have a bearing that is going out. And when I have asked people (not on this forum just people I know )about how to replace it I was told "do the same thing you would do to change the ball joint except only change the hub" those tips didn't really help so I haven't done anything about it yet. So any info would would also be helpful . Sorry that I couldn't help you
Take off the wheel,brake caliper,rotor,front driveline from hub to pumpkin, and unbolt the hub at the knuckle.Bolt in the new hub and re-assemble.Don't forget to hook up the ABS line. It's easy.
