Stuttering and a clunk HELP please
I have a f150 4.2 v6 2002, I started getting a stuttering (like a miss) when starting up from the cold and also when driving on the freeway at various speeds and sometimes when on side roads, I have also noticed a clunk every so often not all the time, I have changed the plugs, wires, coil pack I have sprayed the maf sensor, new air filter, new fuel filter, I did pop a couple of lean sensor codes (401 I think) but changing the previously said stuff turned that off, now I suppose I could change all that stuff again as it did work for a little while but its going to be expensive doing this every few weeks, its becoming frustrating, now with the clunk it has me worried, about 8 months ago I did change the isolator bolts and cleaned everything up pretty good.
HELP with ideas on what to try next would be appreciated.
Tony
Tony
I changed number 1 wire with one of the ones I took off before and I took it for a test run and the stuttering seems to have stopped (well for now) this is a temp fix because I have done that before, does this give any clues, also the clunk only seems to happen when I get the stuttering.
Tony
Tony
