Question about removing TB spacer
Old Nov 14, 2010 | 11:31 PM
jbrew's Avatar
you see the "bracket" extenders?? the tabs underneath it???
Yea, I tried to tell him that earlier, - he wasn't goin for it then. That entire cable bracket moves back, - whether the cables are loose or tight, - they can be adjusted.
Old Nov 14, 2010 | 11:36 PM
Bansheeman6100's Avatar
i never got any of that. i came back into the thread and all your posts were wiped. maybe you didnt explain well enough
Old Nov 14, 2010 | 11:53 PM
jbrew's Avatar
I think you right, - I just took look.
Old Nov 15, 2010 | 07:09 AM
between the military and other job and lack of sleep my brain is a little drained lately . and was mainly worried about the angel of the CAI. i sits paralel with the spacer. when i take it off its gong to be at a crooked angel if thats makes sense
Old Nov 16, 2010 | 07:18 PM
jusr spent a few hours working on the truck. ran some wiring for my efan and got that damn spacer off. the brackets were a little bit of a PITA, but not too much
Old Nov 17, 2010 | 04:26 PM
Veteran: Army
did someone trim the hot air intake tube???
Old Nov 17, 2010 | 04:28 PM
Veteran: Army
you are in the Military and have another job?????
Old Nov 17, 2010 | 06:58 PM
jbrew's Avatar
So , no problem with the cables right ? Yea, it easy to set them back. I guess the most difficult part is having the the right bolts on hand for the throttle body itself.
Old Nov 17, 2010 | 07:21 PM
I honestly have no idea what your talkin about. And yeah I'm
In the guard, not active duty yet. But am a Co. Clerk and personel NCO, Aline with my normal duties. And have been quite busy lately
Old Nov 17, 2010 | 10:46 PM
jbrew's Avatar
That would be the big tube in front of the throttle body. That was a question earlier because you mentioned it wouldn't fit without the TB Spacer. Remember ?
Old Nov 17, 2010 | 10:57 PM
no, i was referring to the linkage next to the throttle cable. that tube was long enough, it justs sits at a sort of off angle now, not as bad as i expected though
Old Nov 18, 2010 | 01:06 PM
Veteran: Army
I hope you aren't Military Intelligence...
anyway, back on topic, post a picture of the intake with the TB removed and I'll let you know if it's been trimmed or not
Old Nov 18, 2010 | 03:43 PM
No I realize what you mean now. There was a bit of misunderstanding on my part in this whole thread. Between post deletion and different terms I feel like a dumbass.
