EGR Probs
Old Sep 27, 2010 | 09:09 AM
bfc4lulu's Avatar
Very Much Appreciated!! Thank you for the jump start!!
Old Sep 29, 2010 | 02:59 AM
Bluegrass's Avatar
If the code/s have not been cancelled, do that next to see if it or another one comes back.
You won't miss anything by trying this.
It may have been a false code or miss read by the last one to read it.
I have seen false codes set before from certain ignition issues that caused it.
I checked on Ford service disc and there is no 404 code listed for any model car or truck with a gas motor, at least as of 2002.
Super Chips code copy does list that code but it may apply to some other setup not a stock motor as normally found in these trucks.
Old Sep 29, 2010 | 03:36 AM
jbrew's Avatar
Yea, I found it here Blue - http://www.svtlightnings.com/scantoo...tc%20codes.htm
It's a Ford list. I haven't looked on the 2002-2004 Service Info Workshop, Wiring (EVIM), PC/ED, Oasis DVD yet. Player being used currently, but yea, I haven't seen that code on the other lists.
I agree , clear the KAM or erase the dtc to see if it reappears.
Old Oct 1, 2010 | 01:43 PM
mrphil101's Avatar
jbrew, pic in post #15 is quite the eye-opener. I don't see any dirt or dust anywhere & its a hi-rez pic. This is an engine used in a teaching environment, right? Dang, i have clean dishes dirtier than that.
Old Oct 1, 2010 | 02:29 PM
jbrew's Avatar
Nope, that's my 98, -272,000 miles. I hate a dirty engine
Old Oct 10, 2010 | 11:03 PM
camopaint0707's Avatar
can you install aftermarkets headers if you have an egr?
Old Oct 11, 2010 | 12:07 AM
jbrew's Avatar
Iknow Iknow, - Yes
Old Oct 11, 2010 | 12:29 AM
so I can?? I can put these on the car?
http://www.autoanything.com/exhausts...0A2606674.aspx
Old Oct 16, 2010 | 08:17 PM
bump??
Old Oct 17, 2010 | 06:05 AM
jbrew's Avatar
bump??
Iduno, - they're for a truck according to the add,- and this is a truck forum. - Not sure what type of car your referring to ?- Good luck all the same.
Old Oct 21, 2010 | 12:22 AM
bfc4lulu's Avatar
Was the DPFE sensor. Ford product only and 65 bucks... I still haven't replaced it and they tell me that's why im only getting 15mpg. Other then that nothing is wrong unless your like me and hate that freaking light on my dash on blast... Anyways, that is the problem, i just dont have the extra cash to replace it right now.
Old Oct 22, 2010 | 02:11 AM
jbrew's Avatar
How do you know, you meter it ? You can get them at any third party parts supplier now. The dealership would be the best choice though.
Old Oct 26, 2010 | 12:19 AM
bfc4lulu's Avatar
My friend who works at the dealership put it on computer for free. Dealer is only place i cant find them around here. 65 bucks.
Old Oct 26, 2010 | 02:55 AM
Rockauto.com:
MOTORCRAFT Part # DPFE4 {#4U7Z9J460AA} Egr Delta Pressure Feedback (dpfe) Sensor; Clip Mount
4U7E-9J460-AA, 2M5E-9P449-AA
$32.79
http://www.rockauto.com/catalog/moreinfo.php?pk=1147133
Old Aug 29, 2011 | 03:10 PM
PirateSignal's Avatar
Jbrew,
Cool post. My Check Engine Light just came on yesterday in my '98, and O'Rielly Auto Parts said the code was related to the EGR. This weekend I will pull the throttle body and clean.
Thx!
Originally Posted by jbrew
You installed an EGR valve right? So either unbolt that or remove the EGR pipe flange nut first, before removing the elbow. If you haven't cleaned the elbow/EGR ports since you've owned the truck, I wouldn't worry about testing the valve operation yet. The 4.6L is notorious for plugging up the ports, - they need to be cleaned anyway.
I have a 5.4L , it's a little different (not much). Bolts circled in yeller are what your after. There's four that hold the TB elbow down, -you'll remove all 4 as the final step in removal.
I'm sure you can figure out how to get to this point once you take a look at it -
Like I said , this is a 5.4L. The 4.6L has a smaller EGR valve and the IAC may be in a different location on the throttle body.
There's a "How To" on this site that may assist, - here -
https://www.f150online.com/forums/ar...ttle-body.html
But yea, b2 has the best shot for yuh (above), -his post/pic is a 4.6L and it shows the ports that get plugged.
There's not much else to it.
