Weird metallic clicking sound!
Old Sep 24, 2010 | 04:49 PM
Ice-Cable's Avatar
Ok It has been quite awhile since I have been on here, but I am hearing a distinct noise coming from my truck and I know all of you can help me out. I first noticed it when I stabbed the accelerator to pass someone, its a strange metallic clicking sound. It stopped when I left off accelerator. Well now i noticed it when I was just driving regular down a road. It sounds like its coming from passenger side directly under cab, but who knows? Anyway if you have had this happen or know what this is let me know, so I can repair it...money is tight nowadays so i hope its something I can do myself. No codes, its a 2001 f150 Screw 5.4, 6" fabtech, diablo programmer, 18x10 wheels 325/65 tires, if you need more info let me know.
Old Sep 24, 2010 | 05:18 PM
jump n's Avatar
Does it change in rate or intensity with speed, on or off the throttle? I'm not a mechanic at all, but 1st guesses are u-joint or wheel bearings? Not just a piece of debris in a tire?
sorry, just re-read and saw that it went away off throttle, then came back. NM the tire thing then. Hope someone points you in the right direction.
Old Sep 24, 2010 | 06:52 PM
Possibly an exhaust leak. You sure it isn't spark knock? Try a tank of premium gas to rule that out.
Old Sep 25, 2010 | 12:39 AM
b2therad's Avatar
Either an exhuast leak or a bad U-joint for sure. Get underneath there and look for play in the driveshaft. Thats a sure sign of the U-joint going bad. Look for a purple-ish colored liquid around it also.. thats a guarantee that it needs to be replaced. They aren't bad to replace either.. only like 10-15 dollars at a local auto parts store.
Old Sep 25, 2010 | 01:52 AM
jbrew's Avatar
I bet it's the cat shields, - Ford has a TSB about it. My 04 did the same thing and they replace two converters under the emissions warranty.
My 98 cat shields started to get noisy , way back when. - First I followed the TSB/ Later, that didn't even work. I removed the shields and that was that.
There's really no other way to confirm other than wrapping a couple large band clamps around them. If the noise goes away , well... Thing is, that won't last forever, -6 months to a year. This is per Ford instruction.
Old Sep 25, 2010 | 08:33 PM
Ice-Cable's Avatar
Ok so I do have the exhaust leak, I have had it for awhile but I have yet to fix it, it is on the passenger side...so that could be it? i will check u-joints tomorrow after work to see if I got play...I do appreciate all the info, and if i find problem I will update! thanks again.
Old Sep 25, 2010 | 10:51 PM
Red02FX4's Avatar
From the picture in your sig, you have a 4wd(?) Check the front CV axles to see if the boots split open n tossed out all the grease
Old Sep 26, 2010 | 09:37 AM
Ice-Cable's Avatar
Yeah its 4x4, and will def check that out...Got a laundry list of things to check here in a couple days...thanks again for all the info.
