3" lrvrling kit and bigger blocks?
Hey guys,
I was wondering if instead of a body lift if I could get all the height with a levelling kit and bigger blocks or from adding leaf springs. Does a 3" leveling kit actually give me a whole 3" in the front?
Pics and opinions would be great !
I took a look it looks great, so 3" level + 3" block puts it at level and a little higher, are those 33's?
http://cgi.ebay.com/ebaymotors/3-Sus...Q5fAccessories
2.5" but this is kind of what I have in mind
http://cgi.ebay.com/ebaymotors/97-03...Q5fAccessories
One problem Jarett R has a 04+ BS, rclack it says you have a 2000 BS
his is leveled with spacers which are legit. If your looking to level your 2000
Just crank your stock t-Bars and but an add-a-leaf or block in the back
DON'T buy a "leveling kit" all they are is reindexed keys, that kill your ride and put a lot of stress on the front end. Don't buy what you can do for free
I cranked my torsion bars 2.25 inches in the front and off road regularly as well as tow regularly without any problems what so ever. I added a taller block in the rear and run 35" tires with my setup.
The only downside I've found is that you can feel more little bumps while driving on crappy roads but with the bump stops further apart taking a bigger bump is smoother feeling.
Just crank the torsion bars and take her for a 10 - 15 mile test run to see if you like it. If you like it keep it and get the truck aligned. If not, put 'em back to your original measurements.
