Daystar Leveling kit ???
Old Sep 8, 2010 | 12:06 AM
Barryrod's Avatar
When installing a Daystar 1.5in coil spacer to a 97 2wd truck, do you leave in the stock coil spring bushing or remove it and just use the Daystar spacer?
Old Sep 8, 2010 | 06:44 PM
green lariat's Avatar
you need to remove the stock spacers and install the new spacers in their place .
Old Sep 9, 2010 | 03:55 AM
MmmBuckles's Avatar
X2. and remember to align the spring correctly in the spacer.
Old Sep 9, 2010 | 11:28 AM
Barryrod's Avatar
New spacer is not offset on the inside at all. It is flat up inside it. These spacers
Old Sep 9, 2010 | 12:24 PM
GaNole07's Avatar
I think he meant to align the bottom of the coil spring in the lower A-arm it has a groove it fits into. I had the same ones they worked out pretty good leveled it nicely.
