Truck Shaking
Truck Shaking
I own a 2002 Ford F-150 and today it started shaking real bad when I put it in gear. This happened in January of 2009, I replaced the ignition wires and spark plugs. It happened a few days later and when I took it to the shop one of the plugs were cracked, they replaced the plug and it has been fine since then. Any ideas what this might be? Thank you
You had two different actions going on.
Your first issue could have been an injector stuck closed or open, moisture in the plug well etc.
The second was either the plug was already cracked before you installed it or you cracked it when you installed it.
If all is well don't spend to much in hind sight except to learn what the possibilities might have been..
Good luck.
Good luck.
