helper spring that doesnt lift?
Old Aug 17, 2010 | 11:14 PM
fawcetteng's Avatar
any suggestions on helper springs that dont lift the truck much?
Old Aug 17, 2010 | 11:20 PM
Red02FX4's Avatar
From my experience of helpers, they aren't for extra lift, they are to support the rest of the springs on a heavy load so the rear doesn't sag as much. If you want extra lift, add one or two more of the longer ones into the mix
Old Aug 17, 2010 | 11:26 PM
thejake1989's Avatar
overload leaf packs. i have a set but havent put them on yet. the bolt to the top of the stock leaf pack
Old Aug 17, 2010 | 11:33 PM
Red02FX4's Avatar
If that is what I think it is.. it would basically be a reverse helper. Instead of being on the bottom for support, it would be on top to create more arch, and that would work also
Old Aug 17, 2010 | 11:35 PM
Woods-Rider's Avatar
You could just install air bags then you could have no lift and only the stiffer ride and load support when needed. I love mine and got them for $50 off craigslist.
Old Aug 17, 2010 | 11:36 PM
yea mine are just like these
http://www.hellwigproducts.com/produ...ad-pro-series/
Old Aug 17, 2010 | 11:44 PM
Red02FX4's Avatar
Jake.. that is some set-up!
Old Aug 17, 2010 | 11:59 PM
thanks. i need to get it installed soon. tailgate season is almost here haha
I used these on my 2003 Scab......
http://www.supersprings.com/superspr...ew_general.asp
Old Aug 18, 2010 | 01:35 AM
Red02FX4's Avatar
Originally Posted by 88racing
That's exactly what I was thinking of when I referred to 'reverse helpers' ..'cept Jake just had to take it to the extreme
Jake ... how close will that set-up be to the bottom of your bed?
Old Aug 18, 2010 | 02:14 AM
Here's Jakes.....
Here's the ones I used......
Old Aug 18, 2010 | 02:18 AM
Haha yea I don't like it sagging when it's loaded. Plus I'm gonna throw some leaf packs from a screw under there to help more.
The should clear just fine actually. I'll let you know for sure Friday hopefully
Old Aug 18, 2010 | 06:56 AM
projectSHO89's Avatar
I installed Timbrens. No change in normal ride or height.
Old Aug 18, 2010 | 01:15 PM
MitchF150's Avatar
I run the Hellwigs.. I like 'em.. For me, they improved the ride. The truck was WAY too soft sprung stock... I like the firmer ride I got with these..
Mitch
Old Aug 18, 2010 | 01:35 PM
mitch can you get a pic of the clearance around the ubolts? mine are longer than that and i just want to make sure itll all clear haha
