97 headlight suggestions?
Make sure to check your build date first!! the early 97 hava a different way of mounting the headlights so you are limited on aftermarket. An easy fix if it is built before 6/97(I think is the date) is to get a later headlight grille support. They are pretty cheap at the junk yard.
^^^ x2 i had some TYC ones and they were great then i switched to some ebay ones and theyve worked out awesome also. one did fog up inside but the seller exchanged it for no extra charge
i just went with the lightning heads. couldnt be any happier with the new look of my front end, little better lighting too
