engine swap
engine swap
i have a 02 f150 with 4.6 and it has the coil over the plugs and i am wanting to put a 99 4.6 in place of it but the 99 has fthe coil packs on the front of the motor. what will i have to do to make this swap . please help me. thanks
sorry jbrew but i have no clue what that means. a little confused, the 99 has the plug wires and i dont think i can use the indivudial coild on this motor.
You may want to let someone else swap this for you. - It's a easy swap, just need common sense.
Why don't you just fix the blowout properly? The only inserts that work permanently are Timesert - and if you blew an insert, you will probably need a BigSert. The other option are the guys at blownoutsparkplug.com.
They will stop blowing out if you install them correctly - no antiseize and 28 ft/lb torque.
i have already blown one out and this is the second one, plus it has some high miles and the heads are about 350 each plus the gaskets. looking at 1000 to replace the heads and gaskets and still hhave a 250,000 mile motor
Yea, you aren't going to be able to do this swap . You would need to use your intake and heads from your old engine or figure out a way to tap hold downs for the coils. That's all that's stopping yuh, - hold downs for the coils.
I would just get the heads fixed. You can rent a kit here, and fix it cheap. Without even removing the heads.
